Wiring to spa bath
20 May 2007
I am fitting a spa bath which has a 13 amp outlet from it.
I have removed my old 8.5kw shower, and was hoping to use the same wiring and pull cord for the spa bath, which i used for my shower but lower the rcd rating, here are my questions:
1. Can i use this wiring and configuration?
2. What do i need to reduce the rcd down to.
thanks for any help.
Stu.
The easiest way to do this is to use the existing shower supply to feed an FCU. If this is in a bathroom then it must only be located on the apropriate zone, and the work will be notifiable to your LABC.
Do you really mean RCD? Or do you actually mean MCB?
Ok, with you i think.
I can fit an FCU in the loft off this supply no problem, and then wire the spa to this.
Is it an mcb?, sorry .... what do i need to rate this down to?
I presume it's 30 amp at the moment with it originally feeding my 8.5kw electic shower, i'm just not sure what size to use?
Also, i presume i could still keep my pull cord which would isolate the fcu/spa once connected.
Hope i am making sense, not the best at explaining.
Stu.
This shows the difference between the devices in you consumer unit.
You need to see what rating the MCB is that currently supplies your shower circuit, and also see wether it is protected by an RCD.
You should be fine keeping the pull cord in the bathroom. This will be a little unconventional, but I dont see any reason why it can't be left like this.
Ive looked and it's a 40amp mcb unprotected at the moment, what size would i need to fit for the spa?
Thanks again,
Stu.
But make sure the spur is accessible, so you can:
isolate for maintenance
fit replacement fuses
reset the RCD if it trips.
