I apologise in advance for posting the same message in two forums, I wasn't sure if this was more of an electrics based problem after I'd posted it in the plumbing forum
I have replaced my hot water direct cylinder (100 litre) with a larger capacity cylinder (125). The original had 1 immersion heater that was wired up to an on/off control switch.
After removing the old cylinder and connecting the new one to the water pipes I then connected each of the two immersion heaters to a junction box and then connected this (using the original immersion heater cable) to the control switch. Unfortunately the bottom immersion heater's cut off keeps tripping so I only heat the top half of the cylinder.
Does my wiring technique leave something to be desired? Is anyone able to confirm whether one 11 '' immersion heater situated near the bottom of the 125 litre cylinder will suffice - it is on 24/7.
If the wiring is ok is it likely that the bottom immersion heater is faulty? If not can anyone suggest anything, I'm a complete novice so any info would be great
Cheers,
Mark
Cheers,
Mark
