Hi All,
I was wondering if someone could assist me.
I am looking at installing a Sensor light in place of an existing light which was already installed.
I managed to remove the old light, and found that there were only 2 wires running (Black and Red).
I have wired an existing light in the house, and can confirm that Red = Positive and Black = Negative in my case.
However, on the back of the sensor light I have 3 connections, Earth, Positive and another connection.
I removed a wall socket in a room, and noticed that it had 3 wires (Black, Red, and Blue), however the wires I have where the sensor
Light is going to be installed, only have the 2 mentioned above. I would assume that the additional wire is needed to activate the light?..
I haven't hooked the light up as of yet, but would assume if I connected the black and the red (without connecting the 3'rd wire) it would act as the light which was there previously, ie. When the switch it turned on, the light would turn on, and can only assume that the 3rd wire is needed by the PIR sensor to activate the light when motion is detected.
Is there anything I can do?.. Or would I have to crawl into the roof, and re-wire from the 3 power cables back down to the fitting…
I was thinking of splitting the Positive and wiring this into the 3'rd connection on the light as well as the positive, but am not too confident as I think it may blow the PIR.
Any assistance would be greatly appreciated.
Hi All,
I went to one of our Hardware outlets, and asked one of the electricians there (or who I was told knew about wiring, although they said they were not allowed to give advice).
I told him on the back of the senor there are 3 connectors, Positive, Earth, and another outlet.
I told him that as far as I could see, the wiring coming out of the ceiling only had an earth and a positive wire.
He told me the 3rd connector on the sensor was a 'Neutral', and that in most cases this was not required to be connected.
He told me to wire the earth and the positive and that the light should work fine (something about AC power not requiring a 'neutral', and that the light would be grounded as it was being screwed into a wall).
I'll give it a go on the weekend, and let everyone know how I went. Advice is still welcome, if anyone knows any different? or if I should do things differently.
Thanks again
Hi All,
Thanks again
