wiring up a whirlpool cornerbath
11 Dec 2009
Nottingham
Hi All,
i have just bought a whirlpool bath and i need info to wire it up to the mains, if it is straight forward i will have a go at doing it it has come with a pneumatic box with 240v in and 11.5 coming out which i beleive is 4 the led lights , a air connecter on the outside of the box and air pipe on top of the pump motor do i have to put a switch inline to control the bath or just wire it up to the ringmain and the user contols the bath once he is in it thank-u 4 any help
phil
Are your aware of Part P and prior notification to Building Control?
Also what BS7671:2008 (17th edition wiring regulations) requires for circuits entering a bathroom?
If not then it's best to emply the services of a competant person.
thank-u 4 that info on part P i have a nephew who is a sparky i think i will get him to do the job i just thought it was straight forward job (DIY) do i need to let local auth know if my nephew wires it up
thank-u phil
Hi Phil, yes, unless your nephew can self certify then he will still need to pre notify building control prior to starting the work.
If the flex outlet, fed from a fused spur from a ring on an 17 ed board, is Outside the bathroom and the flex from the pump runs directly to it through the brick bathroom wall ( in trunking ) and the bath panel is firmly fixed , needing a screwdiver to remove, is this still notifiable work?
