Wiring up extractor fan without double pole FCU?
29 Jun 2008
Cleveland
Hi all, this is my first post on this site.
I am about to install a timed extractor fan in my bathroom to outside wall and was about to commence with the (highly) reccommended FCU situated outside the bathroom. Before doing this, I realised I already have a double socket wired up in the loft.
Would it be safe to use this socket for the fan? I was thinking about running it straight to a second pull cord in the bathroom, then to the fan, with the permanent live coming from a junction box before the pull switch.
Would it be OK to class this second pull switch as an isolator, and what what cable is best for this?
why have two pull cords in the bathroom and why not have the timer starting with the light switch being pulled on, the switch would not be classed as an isolator especially given it should be switched live. A three pole will be required for the timer to operate.
Thanks for your quick replies Chivers and 17th. Firstly, I am trying to avoid as much wall installation as possible, i.e the fused switch, as the walls in my house are made of bloody sand. This is why I was trying to bypass the FCU. I thought it would be OK to run the L and N straight from the socket as it has a 3 amp fuse in it. This would go to a DP pull switch then to fan. It looks to me to do exactly the same thing as the FCU circuit.
The fan is 230V - 50Hz and is to be wall mounted directly opposite the door. In this fashion, I would only need a few metres of cable.
Wouldn't the fan operate ok? I am not carving this idea in stone, and I agree that it would be better to use the original FCU idea, it's just the old plaster is a phooking nightmare to work with.
you need to put a fused spur in but it need not be double pole, 3 core and earth from junction one to provide switching the other gives a permanebt live to the fan for the over run
Two lives - one permanent fed from a three pole switch/fcu is the norm otherwise the timer will only work with the pull cord which makes it pointless
[/quote]
Ok lads, thanks for your info. I'll go with the FCU/light switch circuit after all. And I'll probably swear alot.
Cheers.
