- Joined
- 14 Apr 2004
- Messages
- 23
- Reaction score
- 0
- Country
I've bought a 6m2 devimat and thermostat from Homebase to install in my kitchen. I am about to lay it but have some queries with regards to the wiring.
I have a redundant double socket which I am going to replace with a single box and wire the thermostat up to it for the underfloor mat to be connected to. However there is a step in the instructions I'm not sure about. It says:
"The screening around the black and blue wires of the Devimat should both be connected to the earth terminal within the electrical box ...."
Now each black and blue wire has wire split into two sections. One of these is just twisted. The other is twisted into a short clear tube. Which is the earth? Is the clear tube the screening?
Secondly I am laying onto a solid concrete floor. The sensor for the thermostat is inserted into a 15mm thick flexible tube which runs under the mat for at least 20-30cm upto the thermostat. Initially the instructions say "Decide on the direction of the cable loops and lay the mat on the floor so a channel for the tube can be made. The channel should be deep enough for the tube to finish flush with the floor surface". Yet further on there is a section about installing the mat onto concrete and it shows the floor sensor on top of the concrete with the mat over the top.
Which is it? Do I have to dig a channel? If so what is the best way? If I could lay it straight on top this would be much easier .... and I can afford to raise the floor a little. But would I use much more flexible tile adhesive this way?
The saturday staff kid said I could lay the sensor on top of the concrete and then lay the mat over the top of this (which agrees with the diagram). Can I believe him?
Like all jobs I thought i'd be done by now ... and I've barely started!
Cheers
K
A keen DIY'er - but a noob!
Cheers
K
