You are.Hello - just want to double check I am wiring this RCD/RCCB correctly
Usually it is - because of the arrangement of a consumer unit -it is feed/supply from top and Load from bottom isnt it?
...but it doesn't matter which way it is wired.
I would not ignore the N marking if a manufacturer has bothered to show it.
You must not attempt this. This comes within the definition of Restricted Electrical Works from the Commission for Energy Regulation (CER).Hello - just want to double check I am wiring this RCD/RCCB correctly only its only got 'N' stamped on the left hand side. - it is feed/supply from top and Load from bottom isnt it?
Thanks.
IMPORTANT NOTE:
The OP is in Sligo. IT IS ILLEGAL FOR ANYONE OTHER THAN A REGISTERED ELECTRICAL CONTRACTOR (REC) TO DO THIS WORK. YOU MUST NOT WIRE THIS YOURSELF AS YOU WILL BE BREAKING THE LAW BY DOING SO AND ARE LIABLE TO PROSECUTION.
Visit www.reci.ie to find an REC in your area.
It's not strongly worded - it is simply a statement of fact.a bit strong wording there! - in any case i thought it was law that if you get someone in to do electrical work the electrician must be registered to do the work by law
How many people have been prosecuted so far?IMPORTANT NOTE:
A number actually, including one who was gaoled for six months with none of the sentence suspended.How many people have been prosecuted so far?
How do you know?The OP is in Sligo.
