Aquaris WMF 740 half way through a cycle I could here beep beep.
Went into kitchen to see washing machine had a message DOOR.
Trying to press the on / off did nothing.
Turning the dial to setting 5 from 3 then trying again also did nothing.
Turning it off at the wall then silenced it and door could be opened.
Left it say two hours and tried again, all seemed fine until 32 minutes to go then BEEP BEEP & message again.
Does this sound like the door interlock switch on the back of the door ?
If so when I take it off I need to join a wire or two to be able to use the machine until the new part arrives.
Just remembered that I was using cycle 3 and it stopped at 35 minutes to go.
The next time it happens it was 32 minutes to go.
Please advise.
Thanks.
Please advise.
Thanks.
