wocester 24i junior combi boiler
7 Dec 2008
Yorkshire
hi i have a wocester 24i junior boiler which was installed in 2005 and it has stopped working.
for the last couple of weeks the light has been flashing once per second i have been adding water and then it has stopped but it is dripping from the boiler. Yesterday it has stopped working all together and the light is flashing four times per second and i have no hot water of central heating. i have had a british gas engineer out and he said it was the flexi pipe that was loose he tightened it for me and then it worked but a couple of hours later it has stopped working again and i am back to the same problem.
please could you try and answer my problem as it is very cold here at the moment and i cant keep shelling out £50 every time i call british gas out
thanks
c
It wont cost you £50 because its only yesterday someone was out and you still have the same problem.
Change you contract from the homecare flexi to the full buhna and it will cost you a little more over a longer period with no call out charge
hi thanks for that i have no problem with british gas i am just annoyed that i still have no heating or water and thanks for letting me know about it still being the same problem i will try and get them out tomorrow to have another look
thanks
