Wonky door frame, impossible to repair?
18 Apr 2004
Hertfordshire
I pretty much noticed the door frame just after moving in. I have now replaced most of the new doors, all of which has perfect frames.
For some reason this particular door frame is not level. The top, and one side are completely out by over 1.5cm. It's more than noticeable to look at and more importantly not only does the existing door not fit, I really cannot see how I can fit a new one in the state its in.
I am considering attempting to remove the frame and refit. The trouble is will this bodge the wood ? I can't even get new framing because I'm sure I won't be able to match the material..
IDEAS/HELP/ADVICE PLEASE
I have run into the same issues when replacing doors. One process, the one that requires the least amount of work is to chisel or cut the low side of the frame. make it even by removing the low side then you can shim and play with the trim to cover any gaps. Don't know if it will work for you.
Sometime you can get away with it by using a hacksaw blade when taken architrave off and cut the fixings between the frame and the wall. Re-position the frame with new frame fixing. If you can remove the door stop, you could hide the screw head behind the door stop. Also check there's no electric cable hidden behind the door frame or architrave, it's amazing what some people do to hide the wire :eek:
