I just need some advice on clearing my situation up.
Im in the process of doing a rear extension and making downstairs all open plan (but leaving the hall with the stair case in for fire route), so it will be lounge, dining room and kitchen. The room will be 45 sq m of floor space. The wood burner needs extra ventilation of 65cm sq. The room will have openable windows, trickle vents in bi-folding doors, openable bi-folding doors.
Ive read that buiding regs require a extractor fan to be fitted in a new kitchen in an extension? Mechanical extraction is the wording i think it uses?
Then ive read i should avoid fitting a wood burning stove in the same room as a extractor fan?
So is there no way round this?
Im a gas safe engineer so i understand what an extractor fan in operation can do to a spillage test. When testing gas fire's we have to run all extractor fans in the house when testing and if it passes its ok.
