Hi Everyone,
Recently had a wood burning stove installed, fireplace recess was lined with skamolex fireproof board and a quartz stone surround was put around the opening (only a few inches wide and about an inch think).
Few problems have occured. Firstly, the skamolex board has came away from the recess wall, the adhesive hasn't done the job. Secondly, when the stove is on the stone surround shifts a few mm's and therefore is misaligned (made of 2 tall stone pieces and a piece across the top). I can only assume this is to do with the adhesive used which is moving the stone when heated.
Question is: what can I use to reapply both the skamolex board and stone to the wall to ensure that they stick and aren't impacted by the heat from the stove?
Thanks!
Thanks!
