Having got my workshop built last year, with a lot of great help from here, I thought I'd build a slightly smaller shed this year to a similar design. All has been going well (and much quicker due to learning from previous mistakes), but I seem to have come a cropper with the shiplap -again..!
I got a similar batch (19x125 quality pine), and had it vac treated. It was done in a few days, and I've since left it 10 days before putting it up. Now last time, I got 'shrinkage' along the whole length of each panel, and was advised that I'd used it too quick.
However, this time I've found a different problem. Over a length of 2.7m the middle is 2/3mm 'thicker'. And over the height of the walls (22 layers), that adds up to either a 4-6cm bend, or a gap of 2/3mm at each end.
I went to the supplier to see if it was a batch problem, but their pre-treated stuff was OK. So I'm guessing it's got to do with the ends drying out quicker than the middle. But how long should it take for the whole lengths to dry out?..and what/where is the best drying method?
Cheers.
Cheers.
