Woodburner advice
26 Oct 2009
Cornwall
Sorry is this is a silly question but do I need a connector to join the flue to the woodburner or can I just connect one to the other? Reason for asking is that we have just purchased a stove and were told by the seller we would need a connector or the flue wouldn't fit. When we got the stove home, however, the flue pipe (which we already had) fitted perfectly; if anything it seems to be a better fit without the connector. In case this is relevant:
The flue pipe is 100mm diameter
The connector is a 'female -female' vitreous enamel one 102 mm in diamer
The stove is a pot bellied cast iron one with a top outlet.
I can only offer what I did. Standing here looking at my small morso woodburner, on top there is a cast metal ring collar (50mm high x 140mm dia) that sits on top of the stove with two small lugs with wing nuts that hold it in place to the stove. The 100mm vertical flue (male) then fits into the same collar (female).
The first time I installed it, the metal ring collar cracked, because I thought I needed lots of fire cement to seal the gap between collar and flue and collar and stove. Having now replaced the collar, I learnt that all you need is correct diameter fire rope, pushed down into the circumference gap between collar/flue and collar/stove and nothing else, with the wing nuts only hand tight (tightened from inside the stove).
This allows for any differing expansions between the two different materials. The fire cement was far to rigid, as the temperatures in this area get pretty hot!
So far no problems with cracking the collar and no spill.
If it fits it fits, you don't need anything else.
As for not fire cementing the flue :eek: :eek:
If you are not too busy, it might be an idea to test the working of the flue.
