Hi
I have had my wood burning stove runing for about 6 month now. The flue pipe is out the on a 45 degree bend and goes straight up the chimeny though the registar plate.
The problem I am having is the flue pipe keeps blocking. The chimney is fine it is just the pipe.
When i light the fire smoke comes back into the room this is how I know it is blocked so the fire goes out I then put a tape measure up the pipe which clear the blockage. What ever it is must be a thin film of somthing as i do not see any residue come down the pipe then the fire works fine for a week or 2 then when it has not been used for a couple of days i have the same problem
there is a good possibility that the stove is going to be blocked if there is a sweet smell in the living room
Any advice would be appriciated and i can attach photos of instalation if needed
thanks
grant
thanks
grant
