I want to replace two open fires with woodburning stoves. It will cost between €800 and €2000 to get the fireplaces adapted ( enlarge the recesses) to accomodate the stoves.
I also want to line the recesses with skamolex fireboard and will have to get some infill hearth pieces which would cost another €500 approx. on top of this.
The other option is to fit inset (or insert / cassette) stoves which would not require increasing the opening sizes.
Does anyone know if an inset is as effective as a freestanding stove and are they more expensive?
The house is difficult to heat and I want to use them to heat the entire ground floor by leaving the room doors open.
One concern with an inset is heatloss through the sides and back as both fireplaces are on external walls.
Any other comments would be appreciated.
