I know this sounds familiar, but have read the posts and find the info I need, so any advice appreciated.
So from top to bottom I was thinking (for garden studio);
- 225mm x 38mm wooden floor boards
- (maybe VCL or foil tape joins in celotex sheets)
- celotex
- concrete floor
Will the floor boards be ok directly on the celotex or should I use some sort of treated battens (100mm x 19mm) glued to the celotex to fix the floor boards to, or will this just compress the battens into the celotex too much? I guess you could use OSB T&G over whole floor?
Also not sure about VCL above celotex?
- celotex
- concrete floor
