Sorry if this has been covered before, I wish to lay a wooden floor over the concrete on beam and block floor to my lounge, kitchen, understair cupboard and entrance lobby. In total about 30ms.
I will be removing the skirting, architraves and cutting the door frames to suit a new floor. My questions are these:
1. How do I stick/hold it down, will I need to level the floor.
2. Can I place a border around the edge and if so how.
3. Can an expansion gap be cut under the plaster to form a shadow gap around the edge, leaving off the the skirting.
4. When fitted what type of sealer should be used that will cover the lounge and kitchen, bearing in mind kitchens tend to get wet at times.
I would like to have a go at fitting it myself where possible and don't particularly want to use a cheap clip type system, it would be good if it was solid or a good engineered system. Any ideas on how much per metre square for supply only and where best to buy.
I am sure I will come up with more questions when you guys start asking me some more.
Cheers
Cheers
