Wooden garage door
15 Sep 2010
Norfolk
Hi, I have a wooden garage door which was replaced with plywood by previous owner which is rotting. Can you suggest a good wood replacement, not too heavy but strong that cannot be kicked in and will resist weather.
Tully.
Is galvanised/painted steel not an option for you? Less likely to expand/contract and galvanised will last forever if done properly
Hi Mikejt, I dont want to replace the door too much cost and the mechanism is old but sound. Replacing the four current panels which are a thin ply seems to be my best option, just wandering what wood or ply to use. Tully
If you're replacing with ply, use exterior grade ply and treat it before you fit it to ensure all edges are treated right to the edge. How big are the panels? 6mm seems thin to me. I'd be tempted to use at least 11mm
I suppose you could, although it is more expensive than exterior grade and I'm not sure if there are any advantages to using it for what you want. Perhaps someone else on here has a better idea?
Go for shuttering ply , cheap and resistant. I've had untreated pieces outside for years and while it has discoloured it hasn't delaminated or failed and I've had treated stuff on sheds for decades that is still as good as new.
