Hi All,
I'm planning on constructing a wooden garage / garden building this summer.
As I plan to insulate inside and potentially plasterboard inside do I need a waterproof membrane behind the outer cladding?
The finished building from the house should look something like this only a bit bigger and with a garage door on the rear side.
Obviously it will have a concrete floor so thinking will build a dwarf wall to lift the timbers of the ground.
Any advice?
Also it will be build around an existing concrete prefab that will have 2 of the wall removed along with the roof. the remaining 2 walls will be part of the final structure but will be clad outside and boarded over inside so once complete will be indetectable.
Any advice?
