Hi, I have just laid two courses of bricks ready to build a summerhouse/garden shelter on. Its only three sided, with the front open for access.
I have the frogs up, so before i put the shed on i'm going to lay a mortar course, so the timber can sit level. Going to do about 10mm course in sharp sand, and 4:1, is this ok?
Would i need a DPC here, or will it be detrimental? If so, is it a case of lay mortar to fill frogs, press the DPC into the mortar, then lay 10mm on top of the DPC? The timber is going to be screwed to the mortar then, will probably put a bit of silicone on the screw thread to seal again, though I have heard theres no need, but it wont hurt will it?
