Wooden work surface disaster - help!
11 Sep 2014
London
Hello, I hope someone can help!
Earlier this evening I tried to remove some mould stains from a beech work-top using a solution of water, bicarbonate of soda and washing up liquid.
When the wet patches dried out they were significantly lighter than the rest of the wood, looking chalky and dull. I'm not sure whether the soap has stained the wood or if it has cut through the surface finish causing the dulling, *or* whether the bicarbonate has bleached the wood. When I re-wet the faded area the colour returns to normal (until it dries) .
Is sanding it down my only option? I'm house-sitting for someone and need to fix it before they return next week!
Any help /opinions/suggestions greatly appreciated! :)
How long have you been there such that mould has started already?
Don't risk doing any more damage and come clean when they get home.
And don't offer to house sit again unless you clean up after yourself so that mould doesn't occur.
Its fixable, with the correct skills & time. If its a small section ie next to sink/cooker, you could sand it & re seal. Linseed oil may not be the correct product, I use Danish oil & I am redoing my worktops as we speak.
Have a look on youtube
https://www.youtube.com/results?search_query=danish+oil+on+kitchen+worktop
There are some very good clips, it does take time, but it will look different from the rest of the worktop, so I think you will have to do it all.
I think it may be best to wait for the home owners to return & tell them you can do if they want.
Agree with Diyisfun.
Sand it and use 2 or 3 coats of Danish Oil, not linseed oil. I found it cheapest in Wickes but maybe someone else knows better. V Easy to apply, just wipe it on with a soft cloth and leave overnight.
Looks lovely when finished, but as with any oiled wood, it needs to be regularly re-applied.
