Woodgrain UPVC Frames distorting / failing units
6 Jan 2006
Cheshire
I had new double glazing installed 7 years ago, recently a double glazed unit at the rear of my house failed (misted) and one on my front bay window started to mist.
Called the installers (who are still in business !) - They finally came round to replace the double glazed units.
The fitter noticed that the actual frame on my front bays seems to have buckled, so that the double glazed unit doesn't sit flat in the frame now .. there was a similar observation on the first floor bay windows.
Now I am concerned .... seems like the frames have changed shape and may have caused the double glazed units to fail.
Can anyone please advice on causes and what to do next please?
You have a bay, is it possible the wall is resting on top of the window frames? This used to be very common in older houses and will work reasonably well with thick timber sections, and soft mortar joints that will accommodate a bit of movement.
I don't know how to put a lintel over a bay window if it has no brick pillars.
Hi, when the guys fitted the bay UPVC windows, they used aluminium posts at the joints of the windows to take the load.
Yes, the bay must be resting on the top of the window ... but unsure why the frame has become so distorted at the base, the cill is raised a fraction too.
The force was enough to nearly move the glazed unit, nearly deparating it ..... over 7 years though
