wooshing noise from cold tap (outside)
23 Apr 2011
Derbyshire
hiya all had a outaide tap fitted (cold and hot) both bib taps - all perfect apart from the cold - which is obviously off the high pressured mains
when you open the tap it makes a woooshing noise?! you can over ride it by just turning the tap on more, so guessing its a pressure thing - i tried to turn it down but ended up making a difference to cold water fed toilets - so ended up turning it up more (on stop cock)
any suggestions please
im i being to fussy,
its not a big issue just bugs me a little thanks[/code]
You could turn it down a bit on the isolator to the tap, normally a valve that takes a flat-bladed screwdriver - if it was fitted correctly it will have one.
thanks all, a lot better - had to turn it down 3 quaters - almost off - no were near the pressure - it was to much - i want cold water but i dont want a shower why i put the tap on lol
guessing its just water pressure
obviously hot tap outside doesnt do it (this is generally quieter)
guess this is as the mains is pressured ??
thanks all
