Hi everyone, I've been trying to solve my boilers refusal to start for almost 2 weeks now and I've reached the end of the road (and my patience!!)
It's a worcester heatslave 12/14, it has previously had several undiagnosed lockouts, usually solved by either just pressing the reset button or by switching off for a minute then back on, it would then work unhindered for a while, it has been serviced 12 months ago, but has always been somewhat temperamental!
We returned from a fortnight away, to find the boiler had decided to totally give up (despite both hot water and CH selected to off)
Through elimination the issue seems to be something to do with either the motor or oil pump.
I've noticed that the motor will not turn the pump (just buzzing noise and relay clicks), but with the pump removed the motor and drive assembly spin just fine. The oil pump is brand new, so is the little plastic coupling from the shaft to the motor.
Obviously fuel will not reach the nozzle, but the mains feed is fine and the pump is fed, just no pressure and not turning, but all works well when shaft is turned manually, as oil is pushed out of the bleed valve.
I'm really at the end of my tether now and everyone is sick of cold/bucket showers! I'm one step from reaching for the lump hammer!
New parts are as follows:- plastic drive shaft coupling, oil pump and solenoid, electrodes, electrode transformer, nozzle, nozzle holder check valve and the photocell.
The small gauge pipe from the pump to the nozzle holder is clear also. Any help would be GREATLY appreciated!
