- Joined
- 20 Jun 2006
- Messages
- 8
- Reaction score
- 0
- Country
Hi, Hope someone has come across this before.
1) Boiler make / model (gas or oil) - worcester 15/19 heatslave oil
2) What is / is not happening - CH OK, no hot water
3) Has ANYTHING else been done / changed recently - turned off CGH for summer (switching it back on does not help)
4) When did it (problem) start - week or so ago, no trigger event
5) When does it happen? eg, heating coming on or going off - permanent problem
6) Anything else you feel may be of relevance - CH OK, water pressure low, suspect not triggering flow switch, if I jump flow switch contacts on PCB then pump works and burner kicks-in. What diagnostic test can I do to work out if it is lime-scaled HX causing problem or flow switch is faulty (had multimeter across it and it does not trigger when hot water tap is turned on.
So, which one to go for HX or flow switch and how to go about briefing an engineer.
thanks
thanks
