Hi, having big problems with my 15/19 oil boiler. Motor is getting stuck on start up and humming till cutout kicks in. Thought it was the pump getting stuck with debris, so replaced the pump. It didn't fix the problem. The motor turns when under no resistance from the pump and no mater how hard I try to centralise the pump onto the motor, it is still unable to turn without wiggling the lose pump around. Once started it is fine, but when I try to tighten the pump location screws securely, motor unable to restart as under too much resistance. Can the motor loose it's start up power (torque) over time? Can anything be done to it? It's all well lubrcated and the bearings are fine. Is this a common problem? Most importantly, I think it could only be the motor as the pump is new, what do you all think? and what are motor capacitor replacements and can these solve my problem? It's a Simel motor. Thanks
