When cold the pressure is usually at 0.75 bar but when the heating is on the pressure rises quite quickly to 3+, I then have an issue of needing to top up the following morning as the pressure drops to less than 0.5 bar.
I can't see ant leaks.
Could it be dumping water through the overflow as the pressure is to high?
What causes high pressure (assuming 3+ is too high)
Thanks.
Thanks.
