- Joined
- 18 Sep 2007
- Messages
- 4
- Reaction score
- 0
- Country
I have a Worcester 240 boiler - I have recently had problems where hot waters does not come on. An expert has been out & told me to increase the pressure so it is between 1 & 2 when it happens which has fixed the problem in the past. Same thing has happened tonight, when I have increased the pressure & turned the hot tap on, the boiler fires up for about 30 seconds then the water pressure valve suddenly increases past 3 then 4 and makes a noise like it's about to blow up! So I turn the water off. Has anyone any idea what might be wrong. I scared to keep trying it in case it does blow up! As i'm sure you can imagine it's freezing tonight and I have no hot water or heating! I would be extremely grateful for any advise. Thank you.
