The problem I am having is No central heating, the hot water is fine. Upon inspectin, I can see that the spindle on the divertor valve is permanently in the hot water position. Normally, when you turn the hot water tap on, the spindle comes out and pushes the microswitch. Now, the spindle does not go back in when you switch the tap off.
The spindle feels fine, I only fitted the diaphragm a few months ago. If I push the spindle in, the spring pushes it back out.
My questions are:
How does the divertor valve work
How is the spindle triggered, what pushes it out, Why doesnt it go back in?.
Can I get in the valve to fix problem ?..
All answers greatly appreciated
Many thanks.
My questions are:
Many thanks.
