worcester 240 OF lpg
29 May 2013
Sheffield
Hi my boiler in my static caravan is a Worcester 240 OF lpg its all of a sudden making a very loud vibrating noise when hot water is on for longer than a few minutes doesn't make it when heating on only when on high demand for water felt pump can feel vibrations can some one give me a clue what this could be
It worries me the idea of an open flued appliance in a static home where internal doors are often not very airtight and it could be considered to be virtually in a bedroom.
Although it probably does have the flue spillage sensor which will give a little protection. That's if it has not been bypassed to prevent nuisance tripping!
Tony
Tony
Hi Tony
That's helped a lot i also have a mains powered c02 detector in compartment of boiler but this doesn't answer my question.
mark
You need a detector for CO and not CO2.
I cannot guess what the noise is without being at the boiler.
Obvious answer is to call a competent engineer. Not that many are reg. for LPG but any can deal with it if it is not a gas issue which is unlikely.
Tony
is the water a bit hotter than normal ? the thermistors on these are prone to failing
Don't they flash an orange light on the panel of an NTC goes o/c ?
I think they are about 25k cold unlike most boilers which are 13k.
Yes Tony you are correct but only if they go O/C if just out of range you dont get any indication, could also be heat exchanger scaled
