Worcester 240 rsf
1 Mar 2007
Shropshire
Hi
has any got a copy of a service manual for a 240 rsf i need the part
that goes on the diverter valve all i know is its a little rubber connector
can't find a exploded parts diagram anywhere
Do you mean the black plastic disc off the end of the spindle, that sits under the microswitches?
Stan
no apparently it's a teloscopic peice that goes on the diverter valve that usually leaks if you dont replace it when you do the diaphram in the valve itself i just don't know what it's called to order it from worcester
You mean you want the O ring that goes in the telescopic connection on the supply to the calorifier.
The telescopic assy comes apart so you can replace it and yes you are right they always leak.
Stan
I know you get it with the complete valve assy but cannot help you otherwise.I have a box of O rings and I can usually find one that does the job.
Try worcester part no WORC 87161205070 COUPLING ASSEMBLY
or WORC 87161205360 PIPE FLOW W W HT EX
or WORC 87161408020 O RING
Coupling assy... Tadaaa:
not their finest hour.
no as bad as the telescopic pump connection thingy though :LOL: :rolleyes:
Well done Chris. Never ceases to amaze me where you find all these pictures!
Nickso talking about crap telescopic connections, had to change a reversing valve assy on a Sunier Duval Combitek the other day.
Has anybody cared to note the telescopic connection on the pump outlet! :evil:
Hateful thing.
Stan
right got my plumber in last week he changed the diverter valve and the part that connects on to it as in the picture earlier on a week later we have water leaking and only hot water when the heating is on any help please.........
