Sorry to revive an ancient thread but I finally got a chance to get to work on the boiler, and amazingly, SUCCESS first time, so THANKS for all the advice
I was very lucky that the 16 year-old isolating valves all operated easily and didn’t leak a drop, and the plate HEx came off easily enough too.
Dismantling the diaphragm housing was OK until I got to the two screws nearest the back, but even these shifted with a Ph2 hex bit held in a ¼” ring spanner, then spun out with a flexible screwdriver. The diaphragm was horribly perished with a huge hole in it, as you’d predicted. It’s worth noting that the screw heads are Philips(Ph), not the more common Pozidrive (Pz). The only RA/offset screwdrivers I could find on sale were Pozidriv unfortunately.You get a much better grip and stand less chance of mashing up the heads if you use the right bit
I checked the new diaphragm was centred on its spindle by spinning it in the housing, lubricated its edges slightly with O-ring silicone lubricant, then re-assembled the diverter valve. I took the chance to replace the original screws with M5 x 12mm cap head hex bolts which were much easier to tighten to a sensible torque using just an Allen key rather than faffing around with stupid home-made right-angle screwdrivers. You can get a big pack of stainless steel ones on eBay for a couple of quid.
Hardest bit for me was putting back the plate HEx. Obviously, I used a new fibre washer and 3 new O-rings, but had trouble doing up the union nut on the primary side as it didn’t quite sit squarely against the male threads. I found the best way was to push the HEx half-way and loosely onto its secondary connections, start the nut, then push the HEx fully home, insert the retaining clip and its special tensioning screw on the RH side, and finally tighten the screw and the nut alternately.
I also changed the filling loop as the old one was FUBAR.
Amazingly, no leaks at all and the primary holds its pressure (which it hasn’t done for years).
I had a bit of a shock when I came to test it as the burner fired up then shut down shortly afterwards with lots of banging, and steam coming from the AAV. Fortunately, it was nothing more than the pump had seized from being stood idle and dry for a few days, and freeing off the spindle got things running perfectly again.
Chris.
