Worcester 24CDi RSF
28 Sep 2004
I have a Fail point F with my boiler is there any way of resetting boiler without removing parts :?:
If not is there any chance it's something minor as it only started after, my gas supply was cut off for about 1 hour while i was out and boiler was on :?:
:arrow: This is not a reilable boiler , is there a cheap but realiabe boiler out there if replacment needed
I take it you have tried pressing the red reset button and holding in for a few seconds as described in the users instructions ?
I have tried that however i tried again today with no change so i taken the panel off, it turns out my reset switch was broken i have fixed the reset button ( re solider it ). Reset the boiler and everything is fine now , i also re filled the boiler due to non usage for a while.
:D Dam it's good to have heat again :D
