- Joined
- 31 Mar 2006
- Messages
- 5
- Reaction score
- 0
- Country
Hi All
I've got a Worcester 24CDi combi boiler with a rotary mechanical timer. The timer is on its way out (making a clunky ticking noise all the time) so after checking the Worcester site I bought a replacement digital timer (part 7-716-192-003-0).
Today I removed the fascia to fit the timer. Everything looks fine - just as described in the instructions there is a plug on the right side of the main boiler circuit board with a "timer" symbol on it and the label ST5. The plug fitted to the timer fitted perfectly. With the fascia back on everything looked fine - but the timer doesn't switch the heating on. When it turns on a red light on its panel lights up, but the boiler itself doesn't fire.
I noticed that the old timer was wired into a completely different location, under the circuit board next to where the mains power goes in. It was screwed into three connectors - Ns, Ls and LR, so I'm assuming neutral, switched live and live. This connector is marked ST8.
If anyone's got any ideas as to what could be wrong I'd appreciate it. Is there some way of selecting which connectors (ST5 / ST8 actually controls the boiler, for example?
Cheers
Boris
Cheers
Boris
