worcester 24cdi
24 May 2005
Our worcester 24cdi combi boiler has started making banging sounds and the hot water suppy runs cold on occasion, I feel this is probably my fault as i had to drain the system to move a radiator. Now I have to put a radiator back in the bathroom and am not as you can imagin too keen on draining the system again! Is there any way this can be fixed and any way that I can add a radiator safely?
sounds like you have air in the system somewhere and you have not filled it back up correctly if i where you i would start again drain the system again and dont forget to remove the cap on the auto air vent
thanks guys, when im proply awake ill try that 2moro:)
