B
B.O.B DOLE
worcester 24cdi ch flashing slow what does it say in the book for this has i have lost mine. Once reconnected to gas supply what is the best way to purge these boilers.
tried that 3 times still the sametomy said:It means ignition lock out press reset and all should be well
B.O.B DOLE said:worcester 24cdi ch flashing slow what does it say in the book for this has i have lost mine. Once reconnected to gas supply what is the best way to purge these boilers.
ollski said:B.O.B DOLE said:worcester 24cdi ch flashing slow what does it say in the book for this has i have lost mine. Once reconnected to gas supply what is the best way to purge these boilers.
Just a standard purge via undoing the inlet screw and measuring the volume passed in a given time. Ventilated area and notifying customers etc. Which light is flashing?
ChrisR said:C'mon BOB, the MI for this one are on the WB website!
PEDANTICVINDICTIVEMAN said:Are you kidding, just purging the gas fire aint gonna purge the boiler, if the gas pipe to the boiler isn't purged then of course it's gonna lock out, is this a trick question.
B.O.B DOLE said:PEDANTICVINDICTIVEMAN said:Are you kidding, just purging the gas fire aint gonna purge the boiler, if the gas pipe to the boiler isn't purged then of course it's gonna lock out, is this a trick question.
no ped where on the boiler would i purge it
ollski said:B.O.B DOLE said:PEDANTICVINDICTIVEMAN said:Are you kidding, just purging the gas fire aint gonna purge the boiler, if the gas pipe to the boiler isn't purged then of course it's gonna lock out, is this a trick question.
Gas tap connector on inlet test point on gas valve....probably worth just having a little refresh on your ccn1 purging beforehand.
Agile said:Quite often there is a gas cooker close to the gas boiler if its in the kitchen!
Purgeing at the gas cooker is more convenient. I purge on one large burner but my trainee says he is taught to purge with three burners.
Has the College muddled up purging with measuring the working presure? Or am I just out of touch with the latest working practices?
Tony
