I'm having a problem with my boiler. When i turn on the hot water tap the system trys but fails to light. The reset switch goes onto a 1/s flash.
I've been through the usual basics such as changing the PCB fuses, drained the pump and topped the system pressure to 1.5bar.
If I use the manual configuration switch on the PCB (it has three settings normal on demand, low burn and high burn) and fire the bolier up it comes on fine. If I then switch back to normal mode after a few minutes, turning the heating off and turn the hot tap on the sytem fires up fine.
If i then let the boiler be for an hour and the sytem cools, when i create hot water demand through the tap the bolier fails to start and goes into the usual 1/s flash sequence.
HELP PLEASE!
HELP PLEASE!
