worcester 24i junior
20 Apr 2009
Staffordshire
i have a worcester 24i greenstar junior.when i turn on the hot tap,the boiler fires up,but then the pressure goes into the red and blows all the water out the prv,and cuts everything out,pressure then goes to zero.boiler wont fire up at all when CH is switched on.any help or ideas would be greatly received.
You have not made it totally clear if the heating works OK when you have topped up the pressure to 1.5 Bar.
Regardless, it seems the pump should be checked first and then the expansion vessel needs checking. See FAQ on this site.
Tony
heating doesnt work at all even when pressure is back to 1.5 bar,boiler only fires up from hot tap,but after 10 seconds or so,pressure goes off scale and blows all water outside into garden.
man came to look today,verdict...pressure releif valve,
plate to plate,(whatever that may be?)
and a pressure vessel.quoted £350 all in.does that seem about right price??
I would get someone else in, your boiler does not have a plate to plate.
Chances are your boiler, and whole system is suffering from a bad case of corrosion.
