Worcester 24i Rsf Combi Boiler
7 May 2009
Argyll
My Boiler has started making an awful noise. It is still heating up the Hot water but the central heating isnt working. The pressure is at zero on the guage. Will this be the problem? How do I get the pressure back up? Many Thanks.
u should have two valves under the boiler u should have a filling loop silver hose with females connections either end which attach to the valves then open up the valves to start filling your system should be 1.5 when cold but ull need a vent key to vent rads upstairs
So if I open these valves it should fill the system up and bring the pressure back up?
And turn boiler off while filling
