Hi New to forum.
The 24i is giving hot water that changes temp with flow, an "boiler engineer" tells me this is normal, but because of this the shower wont work properly. The manual says the burner is modulated on hot water between 7.5 & 23 KW. I have roughly measured the heat power at the hot water tap (from flow and temp rise) and it is about 15KW at tap full on and about 14.5KW at min flow, measurement could be a bit out but it seems to me it is not modulating as it should.
With the shower I have and the flow rate with water full on the boiler power which seems to be constant is too much for the required temp rise. Is this boiler working as a 24i should ?
help please.
Paul
help please.
Paul
