B
blippy
I have an LPG 24i which has recently developed a fault on both DHW and CH.
When there's demand, the boiler goes through the ignition sequence correctly, there's a good spark and ignition occurs. Sparking stops once the flame reaches the ignition sensor. However, after about 3-4 seconds one of the relays on the PCB drops out (sometimes it bounces for 1/2 a second), and then the gas valve is turned off (relay 4 drops out). Then the whole ignition sequence repeats, and fails etc. etc.
The boiler was professionally serviced last October, burner pressures adjusted and the burner properly cleaned etc.
I checked everything I can from similar threads here - specifically reversed polarity and ignition sensor condition/connection, but nothing obvious is out of place.
Grateful for any further pointers.
Cheers,
Chris
Cheers,
Chris
