Worcester 24i stops burning after initial fire-up
27 Sep 2007
Warwickshire
Hi - my worcester 24i boiler has been temperamental since I moved the power switch. For both the HW and heating the boiler will fire up ok, but after around 10 mins for the heating and at most 5 mins for the HW (running individually that is) the boiler will stop burning.
At the point where the boiler stops burning, it starts to make a ticking/clicking noise which seems to be coming from behind the control panel; from then not much else happens. It is almost like it wants to restart but cannot. I can hear what I believe is the fan but that is it. I have checked the extraction flue and this is clear.
I am sure I have rewired the switch I moved correctly, the red power light is lit ok.
Any help is welcome. Cheers
It sounds to me as if the APS is not being actuated.
That needs a competent CORGI to check and repair.
I suppose you have never had it serviced properly?
Are you in L/S ?
Tony
Tony, thanks for that - I had heard that the APS maybe the place to start. I'll have to get that checked as you said.
I guess this is indicative of a system that has not been serviced properly :rolleyes:
Not sure what L/S means, so can't answer that...
Cheers JP
