worcester 24i
17 Feb 2004
Hi all
Would anyone have any idea as to where I could find the installation and servicing instructions for the above boiler ? Have tried the Worcester Bosch website, but no luck.
Thanks in advance
Cheers for that, but unfortunately it does not give the info I require. Guess I will have to give WB a call
Thanks again
Cheers Breezer, but that was the users manual. Didn't know you had to be corgi to change the heat exchanger tho.
As far as I am aware you only need to be corgi if you are going to disturb the gas "train" ie anything carrying gas, products of combustion or safety devices.
"Didn't know you had to be corgi to change the heat exchanger tho."
Main h/e you do need to be corgi for - extremely important!!
Secondary h/e's, not as a rule. Not just Gas Train its vents and flue stuff too. Though the law says ANY work.
