Hello,
I have a 24i RSF, about 8 years old I think. The problem is that for both hot water and heating demand, the system seems to go through the correct sequence until actual Ignition. I get sparking at the electrodes but no ignition.
I have semi-ruled out the gas valve as this was only replaced last year.
I'm not sure if a faulty pump would cause this, or would we not even get to the sparking stage if the pump were not running?
How do I check the pump is running?
any help is appreciated,
