- Joined
- 23 Jan 2008
- Messages
- 29
- Reaction score
- 0
- Country
Problem with my 1995 worcester 280 boiler. It some times won't ignite. Seems to be more when I'm running hot water tap. The fan is running as it should and the ignitor is clicking as it should, but no flame, also the gas valve solenoid is clicking so i think this is fine.
It is only doing this sometimes, and up to now seems to be running the heating ok.
It may be a differant problem but also sometimes, it is tripping out on over temp, and i'm having to reset. Flow through the hot water tap seems fine. But am thinking of descaling the water-water H/E at some point.
It's recently had a new fan and new pump fitted. But i've only recently moved into this house so no idea if it's always had these problems.
Any suggestions ??
Thanks.
Any suggestions ??
Thanks.
