Worcester 280 Combi Pressure relief valve problem
5 Jun 2010
Gloucestershire
I accidentally overfilled the loop on my 280recently, and now the system will not remain pressurized. I have read on here its probably down to dirt or a prv jammed slightly open.
Is there any way of re-setting the PRV or will it require replacement? I am not at the house at the mo, it looks as if the PRV has a knurled end that can be removed, what is underneat this and can the PRV be easily "re-seated" or "reset"?
The service manual mentions the PRV is a caleffi 3141 3 bar.
Thanks in advance.
you can't (re seat) a prv
you can remove it and clean it out
you can replace it :idea:
Sweet. For the price, might as well replace then. Another quick question for anyone in the know, how do you get products such as sentinel into the CH loop on a combi?
