I have what I suspect to be a calcified heat exchanger on my 280 RSF. I have the one with the flat, box like water-to-water heat exchanger.
Symptoms:
The exchanger isnt blocked I dont think - the flow rate through the taps is fine. unfortunately, after the tap is turned on, it takes ages - I reckon about 2 minutes to get hot water through the tap, and even then, we are talkingabout 1 litre a minute! Obviously, something is not right. The boiler is working fine - central heating is working great and all the rads are quite hot after 5 minutes of the boiler being on. I am planning a descale of the loop at some stage, probably next summer, however, I cant go on without hot water supply to the taps. The manual recons it can heat 11 litres of water by 40 degrees C - and we are well short!
We are in a hard water area in gloucestershire.
I want to descale, but unfortunately, as I dont know what the secondary HE is made of, I am unsure of what to use in it. I am going to knock up a basic system to flush the heat exchanger through, using a drill powered water pump, a vat of the reagent, and some hose pipe to and from the boiler secondary heat exchanger whilst it is still fitted to the boiler. I am going to tap into the mains supply and return pipes using the hose pipe, then pump the fliud round using a drill powered water pump, from the container of reagent.
Now, I have a couple of options as to what to use. (from least reactive to most)
Heated pure vinegar (works great on the kettle)
Kettle descaling liquid
Dilute HCL
Fernox DS3
I want to go straight for the fernox as its what you guys swear by, but does anyone know what the secondary heat exchanger on the 280 RSF is made of? I dont want to flush an aluminium HE with HCL or DS13 one would imagine.
any other tips/tricks? I am absolutely skint at the mo, I would pay for a new heat exchanger if I could, seems a bit of a waste as I reckon this is down to excessive limescale.
Symptoms:
Dilute HCL
Fernox DS3
