On thursday daytime rads and hot water went off. Thursday nite, turned boiler off at panel and wall for hour or so then pressed reset on panel and switched to ch&&hw.
Boiler fired up ok and got a bath and hot rads but after a couple of hours water ran out and rads went cold.
Switched off for hour or so again then topped pressure up to 1.2-1.5 and booted onto ch&hw.
Again it fired up ok and got dishes and hot rads but after couple of hours again water ran out and rads went cold.
Each time, to get it booted i've had to press reset and before resetting i hear water running when a rad dial is turned up but there is just no demand.
Does this sound like the overheat thermostat? I'm just using the rad settings i normally use so didn't think it is an overheat.
Any information anyone could offer would be much appreciated before i have to call a man in the know! £££££
Thanksalot
Thanksalot
