I've a problem with a 28cdi not firing for more than a minute or two on heating. Ive ruled out scaled/sludged HE as it fires continuously on hot water. It has a new flow thermistor and a 2 month old diverter so they should be fine.
Filling and bleeding the system is a long old process, but all with all rads bled two rads fail to heat up (balancing the system was the original reason for my visit). I'm wondering if the problem is poor circulation caused by the air rather than a problem with the boiler itself. Worcester said this was unlikely but I'm scratching my head a bit as the hot water working fine rules a fair bit out.
Obviously, the two rads not heating are probably due to the boiler not staying on for long enough and I have removed the CH stat control knob to make sure its actually moving the internal part of it which it is.
Any thoughts peeps?
Any thoughts peeps?
